Can anyone assist with these questions on the installation of the '53-'54 Vette rear bumper:
1) the bumper has four bolts extending from the bumper that go into the body; on the inside of the trunk, are the bolts attached to the body using a flat washer and nut or is there a bar or other support that the bolts go through before applying a nut?
2) is the bumper simply drawn tight directly against the painted body with no rubber or other cushion between the bumper and body
3) on my bumper, its curve does not match the curve of the body and the center contacts the body before the ends, leaving the ends of the bumper separated from the body by 3/4 of an inch exposing the underlying fiberglass joint and rivets - is this correct?
Thanks for any help you can provide.
Charles
Charles
