Seatbelt Restoration - NCRS Discussion Boards
  • Walter R.
    • January 6, 2009
    • 269
    For anyone contemplating having their seatbelts restored I would highly recommend Charlie Santorelli. He completed a set for me and did a wonderful job. Charlie's number 908-719-2354.
  • Tom H.
    • December 1, 1993
    • 3440
    Re: Seatbelt Restoration
    I will second that. He did the belts for my 63 coupe. They are awesome. I told you he was good !!!
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
    • Frank E.
      • May 31, 1986
      • 189
      He did mine for my '66 and they were perfect!!!!!
      Frank
      1966 Milano Maroon Roadster
      2004 CE Z06
      • Irby G.
        • November 1, 2001
        • 267
        Hi Tom,
        Could you post pics of yours. I had mine restored and would like to compare them to the work of the master.
        Aloha,
        Irby
        • Tom H.
          • December 1, 1993
          • 3440
          Originally posted by Irby Gauthier (36953)
          Hi Tom,
          Aloha,
          Irby
          Hi Irby !
          I'll try to get some shots of them posted for you later today. I should have shot them before I put them in the car.
          Tom Hendricks
          • Jerry K.
            • September 21, 2009
            • 74
            Hey Walt: What does the restoring of the seat belts actually entail, and are they difficult to remove from a '66 roadster? Thanks.
            • Joe R.
              • May 31, 2006
              • 1822
              Jerry,
              The seat belts are easy to remove from a 66 roadster. As you can see from the pictures, it's just one nut on the inboard side and one allen bolt on the outboard side. Just send them off, reinstall when they come back, voila! I had mine done by Ssnake Oyl.
              Joe
              • Tracy C.
                • July 31, 2003
                • 2739
                Hi Tom,
                Aloha,
                Irby
                Irby,
                Charlie did these about 3 years ago..
                tc
                • Gary B.
                  • February 1, 1997
                  • 6979
                  '66 seatbelt restoration; outer boots
                  Joe,
                  Did Snake Oyl replace the large rubber boots on the outboard sides of your belts? Or did you reuse your original boots?
                  Gary
                  • Joe R.
                    • May 31, 2006
                    • 1822
                    Gary,
                    Ssnake Oyl replaced the rubber boots. One of my old ones had a tear in it.
                    Joe
                    • Joe R.
                      • May 31, 2006
                      • 1822
                      Gary,
                      Joe
                      • Gary B.
                        • February 1, 1997
                        • 6979
                        Joe,
                        Were the Ssnake Oyl rubber boots repros of good originals? One of my boots is torn and as far as I know the repros are all configured differently. I think the repros have a slot where the long metal mounting arm goes thru and the originals don't; or vice versa.
                        Gary
                        • Walter R.
                          • January 6, 2009
                          • 269
                          Jerry,
                          After removing the seat belt send it to Charlie and he will take it from there. The extent of his restoration will depend on the condition of your belt, desired restoration and your pocketbook. He was very upfront and did what he said he was going to do.
                          • Tom H.
                            • December 1, 1993
                            • 3440
                            Irby !
                            Just went out and took a bunch of pictures. They all turned out bad. Just can't shoot good shots of the belts in the car. If you look at Tracy Crisler's picture. His look just like mine !!!
                            Tom Hendricks
                            • Mark D.
                              • June 30, 1988
                              • 2142
                              Charlie has restored several sets for me as has Ssnake-oyl. I prefer Charlie's work. He did the belts for my 69 Camaro recently as well as the ones pictured here for my 69 Corvette convertible.
                              With these, he just disassembled the units and replated what needed replating. He then removed the labels and gave the webbing and labels a good scrubbing which was good enough.
                              Kramden
