Were aluminum manifold bolts used on the 2x4 aluminum intakes, and steel bolts used on the cast iron 1x4'S for C1 vettes?
Aluminum manifold intake bolts
Tags: None
- Top
- Top
Re: Aluminum manifold intake bolts
Steve -
Do you mean you have intake manifold bolts you think are made of aluminum? In 38 years in the auto industry, I've never seen a bolt made of aluminum; they would be hopelessly inadequate for any automotive application, with not much more tensile strength than a pencil.- Top
Stephen------
I'd suggest checking them with a magnet if you think they're aluminum. If there's strong magnetic attraction, then they're steel, probably with a zinc plate.
Aluminum alloy bolts are available, though. They are used for specialized applications and as John Hinckley also noted, none were ever used for any automotive application. Mostly, I think they are used in the aerospace industry for applications not requiring much strength but where minimum weight is desired.In Appreciation of John Hinckley- Top
Ah, here's my story. I was looking for a set of original intake bolts for my slooooowly being put-together engine which is mounted on the engine stand in the basement.....winter project....I have two intakes, a 1x4 and an aluminum 2x4. Haven't decided which way I want to go (or what I can afford), so I'm prepping for both.
Saw a few sets of bolts for sale on Ebay, most of which were way too expensive (one set went for $125), but a guy was selling grade 5 circled AP "aluminum" intake bolts cheap, $10 plus shipping, so what the heck, I bought them. Figured maybe that they went on the 2x4. I just tried the magnet test and they are, in fact, steel, but they look like aluminum. Anyway, it's a nice looking set.
As to washers, page 55 of my Corvette restoration book says washers weren't used.
Thanks again guys.
Steve- Top
