The former is for a 1974 L-48 with A/T (non-CA) and I believe the latter is for a Chevelle with A/T (non-CA). Does anyone know if the latter will work OK on a base 350/195 1974 Corvette? Looking at jet specs etc. they seem identical. What is the difference?
1974 Q-Jet 7044206 vs 7044202
Re: 1974 Q-Jet 7044206 vs 7044202
Paul, the 7044202 I believe is the correct carb for your corvette, the 7044206 maybe a replacement number.I think that the last 3 digits 202 are a common number that is seen for a L-48 Corvette w/auto. the number (4) is the year.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Ed,
I was going by the Black Book and it says ...206 is correct. But I have a rebuilt ...202 coming in for the 2010 season from a reputable source here in Canada. Apparently this is a Chevelle carb but I agreed to its purchase. My research indicates that the jetting specs are the same. I am sure it will work fine but I am curious as to what the differences are.- Top
PAUL-
Try www.carburetion.com/quadnumber and see if that'll help you at all.
Marty- Top
Paul, my 72 L-48 Carb. no is 7044202, which is correct for for my base engine. there is a website that has all the carb. no.'s listed for all gm cars you maybe able just punch in the carb. # and do a search.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Paul, the carb no. is as you posted is correct 206, the, I think the only difference may be the chevelle trans. may be a turbo 350, hence may have a kick down cable attachment. the 400 does not.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
OK, that may be it. If so, no problem. No cable, no problem. Nothing to connect. Yes I have a TH400 with the gas pedal activation. I wish I could convert to cable activation but that is another thread.- Top
Check the specs here. The ...202 and ...206 seem to be identical?
- Top
PAUL-
Are you after replacing a carb that's not quite right or something with a little more punch? Why not have the original(?) rebuild and keep what ya got.
By the way nice and informative site, I booked marked it....THANKS.
Marty- Top
if you are still interested e mail me after the first week of march as i will be back home in Pa. where my info is located- Top
That's the plan. A core was not requested for the purchase. I have a rebuild kit with blue Viton components.
I suspect that modern gas has chewed up the black rubber components in mine.
The new unit will be set to factory specs.- Top
