c3 rally wheels back spacing - NCRS Discussion Boards
  • Sander B.
    • March 1, 2005
    • 499
    what is the factory correct back spacing for the 15x8 rally wheels
    4 or 4.5 ?
    Re: c3 rally wheels back spacing
    4 or 4.5 ?
    Sander -
    You'll have to measure it on a wheel, unless someone else has an "AZ" wheel handy and can measure it for you. OEM specs never used "backspacing" as a measurement; OEM specs used "offset", and all '69-'82 Corvette "AZ" 8" rally wheels had +.50" offset.
    • Lawrence M.
      • February 1, 1995
      • 404
      Sander,
      The back space on a 15 x 8 Rally wheel for a Corvette should be 4 inches. The back space on a 1968 15 X 7 Corvette rally wheel is 3 3/4 inches.
      Larry
      Larry
      2002 Z51 Convertible
      1969 L46 Convertible
        • 15610
        Sander -
        John - The offset I have for the 8" Corvette Rally wheels is -0.5" (negative 0.5"). The 7" Corvette Rally Wheel is -0.28".
        As the wheels got wider, the circumferential centerline of the wheel had to be moved outboard relative to the wheel mounting plane to provide sufficient inboard clearance, particularly with the rear spring ends. The '67 6" Corvette Rallys offset is +0.06", and the earlier steel wheels are +0.44". The KO wheels (including adapter) and '67 "bolt-on" aluminum wheels are the same as the '67 Rallys: +0.06".
        So the "backspacing" of the 8" Rallys should be a little over 3.5", but this is not a very precise measurement.
        The wheel width is measured from the inside of the tire mounting flange, but the backspace is measured from the outside of the tire mounting flange to the mounting plane, so it includes the overall width of the flange at its inside boundary, which probably adds about 1/8 - 3/16".
        • Sander B.
          • March 1, 2005
          • 499
          So the "backspacing" of the 8" Rallys should be a little over 4.5", but this is not a very precise measurement.
          Duke if you say the oem 8 inch wheels are 0.5 '' negative offset
          shouldnt be the back space around 3.5 inch ?
          i have 2 original 15x8 wheels
          they have have a back spacing of 4'' (zerro offset)
          bought 4 new repro wheels localy and while installing them
          i discovered the tires hit the E brake brackets on the trailer arms
          paragon sells repro's with a 3.5'' back space the say
          and others advertise with 4.1/8''
          thanks Sander,
            • 15610
            You are correct, and I corrected my post.
            I don't think any other Chevrolet models used 8" wheels, so one with 4" or 4.5 backspacing is aftermarket that doesn't conform to OE specs.
              John - The offset I have for the 8" Corvette Rally wheels is -0.5" (negative 0.5"). Duke
              Duke -
              That's correct - typo on my part; offset is -0.5" (can't correct my original post - no edit function after someone responds to it).
                • 15610
                ...then I screwed up trying to correct your mistake...
