I have the frame to the point of installing the half shafts.
Do I install the torque struts ( camber ) first. The reason I ask is that the half shafts are about 3/4 inch from the yoke. I didn't want to put stress on the diff.
I placed new rubber bushings in struts. ordered new cam bolts.
Thanks in advance for any help.
Do I install the torque struts ( camber ) first. The reason I ask is that the half shafts are about 3/4 inch from the yoke. I didn't want to put stress on the diff.I placed new rubber bushings in struts. ordered new cam bolts.
I used ratchet straps to get the trailing arms up to ride height. It all fell into place after that. The half shaft was binding because of the angle. ( will place a wedge in 1" ) I guess I will have to put a lot of weight on the frame to move it . The spring seems quite stiff.
