1969 Tank Sticker Code Questions - NCRS Discussion Boards
  • Jeff M.
    • July 27, 2009
    • 67
    Hello, I have started decoding my original 69 427/390 tank sticker and I have a few codes at the bottom that I cannot figure out what they represent. They are side by side toward the bottom of the tank sticker next to last as options above N40 Power steerting. They are 02401AA and 02684AA. If it helps the other options are ZQ4, L36, G81(3:70), M21, U69, N40. Also, I cannot decode the dealer (563) or zone (09). Any help would be greatly appreciated. It is a very original car and I am going to take it to Bloomington to be judged for a Survivor. Thanks Jeff
  • Jack C.
    • September 30, 1992
    • 1090
    Re: 1969 Tank Sticker Code Questions
    Big guess, could one be for Tinted Glass? 2401AA
    My 68 is 02A01AA for Tint.
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
    • Jeff M.
      • July 27, 2009
      • 67
      Thanks Jack, My car actually does have tinted glass, and all of the glass is original so that could be. The big problem is down at the location where theses numbers are, the area that would describe what it is was already too far gone to read. Thanks Again, Jeff
      • Dan A.
        • February 1, 2004
        • 212
        The tank sticker for my 69 also has the 2A01AA code, which is "tinted glass". The second code you mention is actually 2G68AA, which I believe signifies the axle ratio. The code for my car looks to be 2G59AA, which is the 3:36 ratio. My guess would be that yours signifies the 3:70 ratio you mention.
        Hope this helps!
        • David B.
          • July 31, 2004
          • 330
          Jeff,
          Try the Dealer/Zone database on this Board if you haven't done so. I found the following among the data. Any chance it's a 565 instead of a 563 on your tank sticker?
          Dave
          9 565 John Smelter Chevrolet Inc. Unknown Newark Ohio 43055 1970 Unknown
          Dave, 1969 427, 1957
          Previous: 1968 427, 1973 454
