been near 30 years since i installed a new top on our 54. about to install a new one on our 55 . can't remember if the 2nd and 3rd bows are extended foreward to their FULLEST before installing the straps and pads, but i think that's their position before the strap/pads are installed. anybody done one lately whjo can confirm or deny my thinking? thanks guys,mike
53-55 soft top installation
Re: 53-55 soft top installation
Mike, according to John Kennedy's instructions, "Center bow measurement at center of bow, down to the floor along side tunnel, should be 40" +/- .250. Lug at siscor is not a stop. Adjust .50 between".
2nd Design Frame
"Measuring same as above, should result in measurement of 38" +/- .250".
I have used several of John's tops and never had an issue, as long as his instructions are used. Geometry of the top frame is critical for the top to fit.
Brett- Top
will do. you gonna use an al knoch or john kennedy top?mike- Top
Here is a couple of pictures of mine. The flap is the hardest and most important.Attached Files- Top
