C2 chassis VIN stamping location
Re: C2 chassis VIN stamping location
Cengiz bey!
Did you list up your C2s on our www.c2registry.org yet?
Saygılarımla,
MikeMichael Westenberg
#46144
'65 rally red convertible + flip flop interior
'99 torch red coupe + light oak interior- Top
Here's where it is on my extremely late '65. You can see the slot in the top side of the frame. My camera is about where the power antenna would be (gas tank removed). To the left is the fiberglass "cage" for the rear body mount.Attached Files- Top
Still two VIN stampings, even on early '65s (at least as of #01425 -- the last car produced before the strike in Sept '64) of which I have close-up pics of both locations when body was lifted.- Top
April build 67 frame serial number stamped at 2 locations: under the driver door on the top frame surface, and on the rear frame, adjacent to the #4 mount.- Top
Can anyone tell me if they know of a method to bring the S/N on the frame back from being too rusted to make out? I am trying to verify that the frame on my 63 is original to the body, and the numbers on the frame are so rusted that it is almost impossible to read. Is there a chemical wash (I know the guys on TV on CSI could do this in a heart beat) that anyone knows of that will help show it?
Thanks,- Top
I can't help with retrieving your old numbers but remember that the quality of the stamp varied greatly. I just pulled the body off my 65 and there is absolutely zero rust, in fact very little dirt, but the stamp is barely readable because it was stamped so lightly.Can anyone tell me if they know of a method to bring the S/N on the frame back from being too rusted to make out? I am trying to verify that the frame on my 63 is original to the body, and the numbers on the frame are so rusted that it is almost impossible to read. Is there a chemical wash (I know the guys on TV on CSI could do this in a heart beat) that anyone knows of that will help show it?
Thanks,- Top
For what it's worth, I have been unable to see the stampings on my 67 despite looking many times and even wet sanding the fairly rust free frame to bare metal. I suppose they must be there, but I've had no luck. The frame is original to the car.- Top
After reading about two stampings I went and checked my April 65 car. The one on the kick-up is very light and barely readable but there's one under where the drivers door would be and it's very clear.- Top
Going back to the original question, the VIN number is also stamped on the transmission, at least on '64s, of course assuming the transmission is original to the car. On the flange, driver's side rotated 90 degrees from horizontal.
Doug- Top
