Hood Support - NCRS Discussion Boards
Hood Support
  • Donald B.
    • September 30, 1990
    • 56
    Hood Support
    Thanks For All The Help But I Inadvertantly Used The Incorrect Terminology. I Was Reading The "hood Support" Section In The Judging Manual And Used The Terminolgy "hood Latch" When I Asked The Question. Sometimes Getting Older Isn't As Much Fun As It Used To Be. My Question Concerning The Hood Support Was Whether An F-15 Car Would Have The 2 Bolt Or 3 Bolt Attachment. On The 3 Bolt I Believe That 2 Of The Bolts Join With The Inner Fender Panel And The 3rd Bolt Goes Through The Rain Channel. The 2 Bolt Support Utilizes 2 Bolts Through The Inner Fender Panel Only. That Is The Question I Was Trying To Ask. Sorry.
    And, I Would Also Like To Know If The Distributor Hold Down Bracketry Would Consist Of The Solid Steel Bracket Or The Steel Wire Bracket?
    Thanks Again For All The Help.
    Don
  • Jack C.
    • September 30, 1992
    • 1090
    Re: Hood Support
    Don, on my 68 F-22 car, the hood support is bolted down into the left fender well area with two bolts only. My distributor clamp is the solid stamped steel piece and not the wire type. I hope this helps.
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
    • Donald B.
      • 56
      Re: Hood Support
      thanks again, jack. i was hoping to hear from you since our cars are so close together. i'll probably have some more questions in the next couple of months. don.
      • Jack C.
        • 1090
        Re: Hood Support
        Feel free to contact me any time.
        Jack Corso
