Does anyone have any tips for cleaning out the metal tubes on 1970 wiper arms. My drivers side has a clog.
1970 Wiper Arms
Re: 1970 Wiper Arms
Les,
About 5 to 10 psi of air using a tip with a small hole that fits inside the tube worked for me. As Dick mentioned you can soak them first to loosen things up.- Top
Re: 1970 Wiper Arms
Yet another way to clean the nozzles is a product called CLR(calcium, lime , rust) I know most hardware stores carry it. just soak over night.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Re: 1970 Wiper Arms
Carburator cleaner with the tube in the hose end works for me. You can then see if all three holes are open by the vapor. If one of the side holes is pluged a needle will go through the open side and unplug the cloged hole as they are in line.
LyleLyle
- Top
