Any of the normal after market outlets sell a successor to 1116577, the ignition switch for a 1960 Corvette?
Ignition Switch
Re: Ignition Switch
Loren------
The last available GM switch I can find was GM #1116517 but it's discontinued. However, Dr. Rebuild has a replacement switch. Costs about 80 bucks.In Appreciation of John Hinckley- Top
Re: Ignition Switch
Loren - Please double check but if I remember correctly the original 1960 (1958-1960) Corvette ignition switch is p/n 1116547. Part number (p/n) 1116577 is the ignition switch for the 1961-1962 Corvette. Pete- Top
Re: Ignition Switch
Pete------
I show GM #1116547 as applicable to 58-59 Corvette and 1116577 as applicable to 60-62 Corvette.In Appreciation of John Hinckley- Top
Re: Ignition Switch
Delco Remy application index agrees with Joe, '547 thru '57, 577 60-upBill Clupper #618- Top
I knew you guys would straighten me out. Pete
