OK, what type of tube is used to connect the carburetor to the fuel filter (the glass bowl type)? This would be for a single four application if it matters.
56 fuel filter to carb connection
Re: 56 fuel filter to carb connection
Yes round pipe type , it's just so long so that when you start one end into the Carb and filter at the same time you can tighten them with out the filter touching the Carb. Same as my 55 , 57 should be the same ! Guessing on how long that is!- Top
Hi Ed,
I guess I did not see your post before.
Attaching a picture of the nipple on my 57 bowtie 220 HP 1x4
DaveAttached Files- Top
