Flat Leaf Springs on 1960 - NCRS Discussion Boards
  • Joe M.
    • April 30, 1990
    • 1338
    It is time to replace the rear leaf springs on my 1960. After looking at Eaton Springs price to rearch the correct way, Corvette Central's price looks good enough to me. I will save the original springs. Is the set sold by CC as good as anyone else's?
    I looked at ST-12 and it appears to give a good description of removing the springs. However, I would think the new springs would need to be "flattened" or loaded some so that the front eye bolt holes and the rear shackle holes lines up. An article on the Restorer CD discusses building a device to make this easier using a 4" by 4" by 31" piece of box steel with chains and a bottle jack. Any suggestions?
  • Terry D.
    • May 31, 1987
    • 2690
    Re: Flat Leaf Springs on 1960
    Joe
    I put a set on one of my 62's a couple years ago and didn't need anything but a bottle jack. Support the axle housing with jack stands, put thr spring in above the rear cross member, if you put it below the rear cross member you get a serious California rake. Next bolt the spring to the axle housing. Then using the bottle jack between the axle and the rear shakle, put pressure on spring to flatten out enough to attach front bolt.
