Carburator torque spec to manifold - NCRS Discussion Boards
  • William F.
    • June 9, 2009
    • 1354
    Re: Carburator torque spec to manifold
    Sorry,
    That's not what is says in Chevy service manual , or in Holley overhaul manual, or by voice from Holley tech line.They all call for 65-80 IN. lbs. which would be 5-6 FT. lbs. Call one of the better carb restorers -Mc Neish,Eric Jackson, etc.-they all warn against overtightening carb.
      Originally posted by William Ford (50517)
      Sorry,
      I understand the sensitivity of that attachment relative to cracking baseplates if over-torqued, which is well-known, especially if thicker aftermarket gaskets are used.
      However, Engineering specified 14-18 ft-lbs. in the Assembly Manual, and that's what the cars were built to.
      I've never seen a torque spec for that attachment either in the Chassis Service Manual or in the Chassis Overhaul Manual; only in the Assembly Manual.
