Opinions on 71 underneath.
Re: Opinions on 71 underneath.
I don't own an automatic C3, but I'm fairly sure the automatic transmissions weren't blue...I'm thinking natural, both on the housing and the pan. Maybe it's a rebuilt transmission, and the rebuilder's color is what the restorer thought they were supposed to be. That kind of calls the quality of the whole restoration into question; I would definitely check the transmission numbers.
Frame is a little too glossy IMO, and it appears to have been blacked out near the frame rails Underbody fiberglass is natural except for minor overspray near the frame rails and some undercoating near the rear differential. Beyond that, you would have to take it item by item with more photographs.
Did you have specific reservations?- Top
Looks like a nice driver that's had some money spent on it. Hard to tell from one picture, but I don't see anything too awful bad. Don't care for the blue tranny, but that's minor.
Tom Hendricks
Proud Member NCRS #23758
NCM Founding Member # 1143
Specialist for 27 years at BUDS Chevrolet.- Top
I've been trying to figure out the roughness on the fiberglass pans under the seats...I also believe the underbody has had some fiberglass repair. That may be why they've used semi-flat black paint on some areas of the underbody fiberglass...they're trying to conceal some rough repairs.
Edit: Oh, yeah, Dude, this is totally messed up right here. There are supposed to be two reinforcing plates that the front of the seat rails bolt to/through. It appears that just the ends of those plates are visible with extra long bolts, and the rest of the plates has been covered over with resin and mat.- Top
Tom------
That blue-painted transmission has got to go. The problem is that you'd have to remove the transmission from the car, so it's probably not worth it. The THM-400 should be natural cast aluminum with the tin parts being natural steel. This blue must be some commercial transmission rebuilder's idea of how to make a transmission look "pretty".In Appreciation of John Hinckley- Top
Trans crossmember drops out without much problem. Borrow a transmission jack and you're good to go.Tom------
I was thinking "ugly" more than "pretty."
My comments:
Floorboard injury; may also be missing drain hole & plug on that side; I can't tell.
Blue transmission
U-joints have been replaced.
Flat black trans mount; probably cheap Chinese piece
Frame a bit glossy; possible powder coated?
Rear crossover brake line not aligned correctly. The "dip" in it should be centered not off to the left.
Battery ground cable has exposed copper wiring. Eventually this will corrode and cause major issues. This comment based on the "personal experience" factor.
That's what I see on first glance.Vice-Chairman (West), Michigan Chapter NCRS
I first thought that roughness was undercoating also, but I believe its resin and mat "as laminated".- Top
