Anyone have an idea why the two inner rear brake lights / directionals won't light up? They work as tail lights but won't light either with the brake pedal or the directional lever...
67 Rear Inner Brake lights don't light
Re: 67 Rear Inner Brake lights don't light
Sounds like you are missing the ground on the inner lamps, or the incorrect bulbs are installed.Bill Clupper #618- Top
Maybe, but the symptom you just described is textbook for a bad ground.Bill Clupper #618- Top
Yes we had that problem, on the driver side, at the Winter Regional this year. We caught it before the show started and used contact grease to temporarily fix the problem. We havent fixed the glitch yet but I am guessing the socket is not grounded properly in the hole. If you fix it please share whith us your findings.
Good Luck!
Chuck- Top
Remove the bulb, hold brake pedal down and test each contact point in the light socket with a test light. Each one powers one of the filaments in the bulb and both must work for the "bright" light of a brake or turn signal light. Sounds like one is not working. If it is working, the bulb might not be making contact on one of the "lead" contact points with the juice contacts in the light socket. Be sure the spring is working inside the socket on each contact point.Avatar--My first ever vette, owned 3X since 1977, restored 1993-2024. Top Flight Award 9/14/24- Top
Bill,
If the ground was bad the parking lights would not work so forget the ground.
The wiring is pigtailed and does not go to the front.
I would suspect that someone has already messed with the wiring in your 67 and screwed it up.
You are going to have to get on your back with a voltmeter and trace the wires.
JR- Top
Bill, I have a 63 wiring diagram, not sure if the same as 67,the inner lamps for the turn and stop are just jumpered from the outboard lamps wire colors are pink and voilet colors(brown is tail lamps). seems strangle that there would be a problem with both, but as joe says do your voltage tests at those wire colors. there is a body connection where all the wires must go through the rear firewall.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
They are jumpered together, but a separate ground wire must be attached to each housing (under the speed nut that holds the mounting pin in place) for the stop lamps to work. The parking lamps can find an alternate path to ground, but the stop filament requires more current and needs the individual ground wire to each lamp housing.Bill Clupper #618- Top
After volt testing and finding no voltage to the center brake lights, I worked my hand up and pulled the plastic plug free of the light and tested it again. Nothing.
I pulled the rubber boot back from the plug and found that the yellow (left) and Green (right) wires were coiled in the boot and not connected into the plug at all. Disappointing to find that in a new Lectric Limited harness.
Clipped the wires into the plug and now I'm lit up properly. Thanks for all your replies...- Top
