Dash Bulb / Wire Locations - NCRS Discussion Boards
  • Steve D.
    • November 1, 2002
    • 17
    Fellow members:
    Somewhere in the past there was a great picture of the rear of the Mid Year Cluster, showing bulb and wire locations...I have searched the archives and I am not able to find such a post...Does someone know where I might find this post? Or does anyone have a picture of the rear of the cluster showing wire/bulb placement??
    Also is there a bulb that can be used on place of the stock dash bulbs (gray wire) that gives more illumination to the cluster??
    Thanks, Steve
  • Jim W.
    • April 1, 2006
    • 228
    Re: Dash Bulb / Wire Locations
    Try searching posts by Tim Ehlers. It was "gauge cluster removal" Jan 9th 2009.
      Steve -
      Great photo put together by Dave Zuberer of a '67 cluster wiring arrangement is below; '63-'64 is essentially the same, except you don't have the two extra illumination bulbs below the tach and speedo (you only have seven, not nine).
      #1817 bulbs are brighter than the stock #1816 bulbs; one source for them is Atlanta Light Bulb (or something similar to that).
