Should there be a grommet in the hole the tail light wire harness and antenna cable pass through on the way to the trunk?
Looking at the AIM, I see the cables and the hole in question in section 12, sheet 1.00; section 12, sheet 3.00; and section 102, sheet 1.00. None of the drawings indicate a grommet.
I found a similar question in the archives with no clear answer.
While there is no exposure to the weather, the wire could be subject to abrasion.
Thanks for the help.
