heat slot revisited - NCRS Discussion Boards
heat slot revisited
    • 15610
    Re: heat slot revisited
    Pipe threads are not inches. It's just 1 pipe, 1/2 pipe, etc. This application probably calls for 1/8 pipe. A google search will likely give you a table with the actual dimensions along with the drill size required to run a given size pipe tap.
    My concern with those little Welsh plugs is that they are probably pretty thin material and may rust out over time, so I think a suitable size pipe plug is a better way to go.
    • Al R.
      • June 30, 1988
      • 687
      Thanks guys, I'll make this change when I pull the carb off next time
