'64 front bumperettes - NCRS Discussion Boards
  • Charles C.
    • May 31, 1978
    • 65
    The reproduction '54 front bumperettes from Corvette Central have a sharp front edge. Should it be rounded like the original 58-62 or is a sharp edge correct. If rounded, is there a correct reproduction for the '54 like there is for the 58-62?
    Thanks.
    Charles
  • Roy B.
    • February 1, 1975
    • 7044
    Re: '64 front bumperettes
    Your right they should be rounded (original) some repro's are made in two pieces making them sharp. Seen many like you said on restored cars. Also many repro headlight screens looking flat, that dont following the fender line ,easy to tell there repro too.
    Soom repro's can be identified from 3 feet away
