1961 Oil Dipstick - NCRS Discussion Boards
1961 Oil Dipstick
  • Ray C.
    • June 30, 2001
    • 1132
    1961 Oil Dipstick
    I just purchased a dipstick for a 1961 that was removed from a 1959 Corvette. I asked the normal questions, length of blade , distance to the full and add lines and is there an "M" on the blade. I just received the dipstick and everything is exactly the same as my original 1961 dipstick (different car) except for the "M" is on the handle and not the blade. What year dipstick did I receive?
    Thanks for any information!
    Ray
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 1961 Oil Dipstick
    It doesn't matter both are correct. The blade was from a long stock material and it depended where they cut it off . Also the the markings were stamped in . The logo is to tell what company made them and some don't have a logo but are still original.
    • Roy B.
      • February 1, 1975
      • 7044
      This is my original 55
      • Ray C.
        • June 30, 2001
        • 1132
        Thanks! Roy
        Ray
        Ray Carney
        • David L.
          • July 31, 1980
          • 3310
          Ray
          Ray,
          Here are 4 different 3739830 dipsticks that I have owned. There were at least 3 different companies (and maybe even 4) that made dipsticks for the 58-63 Corvettes & Chevrolet trucks. I believe the dipstick with the "M" and "debossed" stamping (depressed) was the more one one used on the Corvettes.
          Dave
          • Roy B.
            • February 1, 1975
            • 7044
            Originally posted by David Liukkonen (3775)
            Ray,
            Dave
            David! Thanks you just made my point and I copied your pic's , is that OK
            • David L.
              • July 31, 1980
              • 3310
              Roy,
              No problem. There are other threads about 58-63 Corvette dipsticks. You should check those out. I have about 50 or so dipsticks from various 60's and early 70's Chevrolet models that I have collected over the past 30 or so years.
              Dave
              • Roy B.
                • February 1, 1975
                • 7044
                Thanks I'm always interested in other years , I posted the 55 because I'm helping to put the 55 JM to gather--Roy
                • Ray C.
                  • June 30, 2001
                  • 1132
                  Thanks! David, Great Pictures
                  Ray Carney
                  • David L.
                    • July 31, 1980
                    • 3310
                    Roy,
                    I don't have a 55 dipstick but I have an original 56-57 Chevrolet & 56-57 Corvette (2nd Design) dipstick from a 1956 Chevrolet 265 engine. I believe it is GM # 3722959. The "ADD" and "FULL" stamping are EMBOSSED with the marks spaced 21/32" apart. There is also a small letter "E" stamped on the handle. The NORS 3722959 dipstick that I bought over the counter in Sept. 1989 has a large letter "B" stamped on the handle and the "ADD" and "FULL" marks are stamped NORMALLY with the marks spaced 1 1/32" apart. The distance from the "FULL" mark to the stopper measures the same on both 3722959 dipsticks, 19 1/2" or so. The "A" dimension in my 1963 parts catalog is 19 31/64" while the "B" dimension is 20 7/16". The NORS dipstick, however, has a longer handle and a longer stick.
                    Dave
                    • Roy B.
                      • February 1, 1975
                      • 7044
                      Dave
                      I have a large collection of NOS pic's (parts) for 55 and had 56-57 when I had those vetts but deletd them and sold the parts . this is a NOS 55 stick #3717868 first design , later stick dint use the arrows .Nice to see you keep pic's for later discussions to talk about
                      ROY
