68 spare wheel and ncrs judging - NCRS Discussion Boards
  • Jeff G.
    • October 25, 2006
    • 187
    Re: 68 spare wheel and ncrs judging
    Originally posted by Patrick Nolan (48743)
    Jeff,
    Does your spare also have the little BB sized welded dot on the rim that aligns to the paint mark? Hard to tell from the photo but it looks like it is there. Not all spares have this dot. I think it was a "high spot" marker but not sure.
    You know what, I can't remember now where that BB is. Looking at my photo it appears it's not there. Is it possible the BB is on the opposite side? When it get's warmer I'll go drop the tub and look. I get confused on the high / low side stuff too.
    Jeff
    • Jeffrey A.
      • October 22, 2006
      • 273
      Steve
      I have a 68 Coupe I am restoring and I have done alot of research on the correct paint for the rim. Listed below is that I used. This was given to thru posting on the Discussion Board. I help this helps you . I also attached a picture of one of rims after it was painted. This color is only unique to 68
      Brand Code: 5471 Main Layer
      Mixing Scheme: Deltron 2000 (DBC)
      SKU Desc. Inc. (part) Cum. (part)
      DMD 649 Clear 152.7 152.7
      DMD 1687 Med. Alum. 360.4 513.1
      PRL 93 Gold Pearl 53.3 566.4
      DMD 641 Yellow 21.3 587.7
      DMD 691 Black 12.4 600.1
      DMD 646 Weak White 4.9 605.0
      PRL 91 Green Pearl 4.9 609.9
      DMD 1693 Green 3.8 613.7
      DBX 1689 Clear 418.5 1032.2
      Good Luck - Jeff
      • Dale C.
        • November 1, 1999
        • 844
        #18
        Jeff
        Is there a way you could make the picture bigger or take one closser to the paint? It was too small to actually see the color.
        Dale
        • Jeffrey A.
          • October 22, 2006
          • 273
          #19
          Dale, I be at my garage this weekend working on the car and I will take some close-up for you. Jeff
