69 idle control solenoid - NCRS Discussion Boards
  • David P.
    • February 1, 2002
    • 1
    I have a 69 350 300hp with AC!! I need the entire unit with bracket etc!! Is this the same as the Tri-power uses??? Where can I get the parts??
    Re: 69 idle control solenoid
    David-----
    The solenoid bracket is NOT the same as the tri-power solenoid bracket nor is the associated clamp the same as the tri-power.
    The tri-power bracket and clamp are now being reproduced but I don't know if the others are. If not, a used piece will be about your only option.
    The solenoid, itself, is available in the automotive replacement market as manufactured by Standard Automotive Parts. In configuration, it's very close to the originals. However, the "numbers" are, of course, different. Otherwise, there are NOS examples of this solenoid around. What you'll be looking for is a GM #1114421.
    By the way, not all 1969's, particularly early 1969's, with C-60 had the solenoid. Are you sure yours did? Is there any evidence of its having been installed (e.g. an unused wire in the engine compartment)?
    • Erv M.
      • February 21, 2007
      • 445
      I too have a 69 350/300. I am positive the 350/300 did not have the solenoid. I researched this awhile ago and felt comfortable entering my car to be judged at the regional level. I did not have a problem and received no deduction for not having one.
        Erv------
        Is this car equipped with C-60?
        • Jeffrey S.
          • May 31, 1988
          • 1879
          My early '69 350/300 with A/C does not have the solenoid.
          Jeff
          • Erv M.
            • February 21, 2007
            • 445
            Erv------
            Joe, Yes my car is equipped with factory air.
