53-55 6 cyl vs. 8 cyl flexplate - NCRS Discussion Boards
  • Troy P.
    • February 1, 1989
    • 1279
    Can anyone fill me in on the differences in the auto transmission flex plate between the 6 cylinder part and the 265 V8 part? I'm guessing that only the 6 cyl part has the little steel ball embedded in it for timing alignment. Anything else - number of teeth on the ring gear, bolt pattern, etc.?
  • Jean C.
    • June 30, 2003
    • 688
    Re: 53-55 6 cyl vs. 8 cyl flexplate
    Troy,
    I'll move you to the top of the list.
    Someone must have the info Troy is looking for.
    Best regards,
    • Tom P.
      • April 1, 1980
      • 1814
      The bolt pattern for attahment to the rear crank flange is also different. You CANNOT physically interchange 6-V8 flywheels/flexplates.
