There has been a discussion about Luggage Racks recently. (Here: https://www.forums.ncrs.org/showthre...76654&uid=5931, especially see the pamphlet by Willcox attached there.)
Although confident that the Luggage Rack installed on my car is original (well, not installed at the factory - as can be seen from its lack on the Dealer Invoice - but a correct replacement part installed by the dealer later), I nevertheless wanted to check for the "weep holes" mentioned in the documentation by Willcox.
Now, what I found, certainly puzzled me:
- all the weep holes are there and facing to the rear of the car
- all a-okay for the three driver-side bars/struts/spokes
but
- on the passenger side the weep holes are not on the UNDERSIDE of the bars, but facing UPwards
(not too workable for their use of letting moisture drain DOWN, is it?)
The bars seem to have been able to be put into the frame either side (weep hole facing sky- or earthwards). In the "upside down" position the pins showing the location of the brackets holding the T-Tops seem to look better fitting, too...
As the racks came completely assambled from Duer
but
(not too workable for their use of letting moisture drain DOWN, is it?)The bars seem to have been able to be put into the frame either side (weep hole facing sky- or earthwards). In the "upside down" position the pins showing the location of the brackets holding the T-Tops seem to look better fitting, too...
Well, if I just start unscrewing the two screws (it's only one bar in question that attaches the rack to the deck) I might see the screw lifting (a sign that the well nut keeps clinging to the deck) or if it does not, that motion broke the well nut loose..... Case 1: go ahead; case 2: stop immediately, fasten screw and forget about it.
