74 rear bumper covers - NCRS Discussion Boards
  • Robert S.
    • September 7, 2009
    • 52
    Anyone have any info on which '74 rear bumper covers are best, Ecklers or ACI. Someone mentioned the edges are more accurate on the Ecklers, and someone said the ACI is better quality. I would choose the flex-fiberglass two-piece version offered by either company. Anyone's feedback would be helpful.
  • Glenn D.
    • May 31, 2002
    • 137
    Re: 74 rear bumper covers
    Robert :
    Did you do a search ? There have been a number of posts on this topic. I used Tru Flex with good results.
    • Robert S.
      • June 30, 2001
      • 230
      My 74' had ACI front and rear bumper covers installed just prior to my purchase. The rear is the two piece design. Both the front and rear fit fine (follow the body contours) and look good on the car. Please note there is not much flex in these flexible fiberglass covers - nothing at all like the original urethane covers.
      • Glenn D.
        • May 31, 2002
        • 137
        Robert :
        The May issue of Corvette Fever magazine has a seven page article on the replacement of the urethane bumper cover. You may want to check it out.
        • Paul B.
          • April 30, 1995
          • 482
          ....when I did my '74's rear cover six years ago I looked at all of them. I thought the Eckler's true two piece FlexFit one was the best. It seemed to have the correct contour of the middle seam that had the correct rounded edges, not flat or squarely shaped edges of the seam like other covers have. The worst bumper is the "one piece" that has a phony "saw cut" seam going down the middle. On a darker colored '74 you can barely see it.
