For a '62, did the bolts that mount the water pump have washers? If so, were they lock washers? Or, regular washers?
'62 Water Pump Mounting Bolts
Tags: None
- Top
Re: '62 Water Pump Mounting Bolts
Christopher------
As far as I know, no washers, split lock or flat, were ever used, for 1962 or any other year, for any small block or big block waterpump attaching bolts.In Appreciation of John Hinckley- Top
Dan------
I can't say for a 1962, but for later years if there was a brace that was also attached by the waterpump bolt, then there was a lockwasher between the bolt head and the brace, but none between the brace and the waterpump. I suspect that this was the same for 1962.
Also, for later years, if a hex-flanged stud was used for waterpump attachment and also for generator brace retention, there was no washer between the stud's hex flange and the waterpump, but there was a lockwasher between the brace and the nut installed on the outer end of the stud.In Appreciation of John Hinckley- Top
