holley 3810 fast idle - NCRS Discussion Boards
  • Timothy B.
    • April 30, 1983
    • 5177
    Can someone give me the GM published spec for fast idle RPM for my 3810 Holley. I read the Chiltons book and it lists 2000 RPM with hot engine but I keep thinking 1750 for some reason..
    Thanks in advance, Tim
  • William C.
    • July 15, 2009
    • 239
    Re: holley 3810 fast idle
    GM Overhaul Manual shows 2000RPM for 67 300 & 350HP. I think the judges are looking for 1300RPM cold fast idle.
    • Timothy B.
      • April 30, 1983
      • 5177
      William,
      Thanks for the response to my question about the Holley fast idle. I will set it at 2000 rpm, I think the Carter AFB is set at 1750.
      • Mike M.
        Director Region V
        • August 31, 1994
        • 1464
        FWIW...
        The '63-'67 Ops Manual & PV Test Guide states.
        " approximate fast idle, '66-67 327 engines... 1500 - 1800 RPM"
        HaND
        • Timothy B.
          • April 30, 1983
          • 5177
          Mike,
          If you set it at 2000 RPM hot, the idle probably falls in the range you describe when the engine is cold..
