This has to do with a 1971 convertible but I suppose the deck lid would be unchanged from at least 1970. The deck lid does not sit flush to the rear clip mostly along the entire rear most edge. The front where it locks into the recivers is ok. Net result is an uneven transition from rear clip to the lid.
Is there an adjustment point somewhere at where it hinges? If the hinge could be dropped a bit it might fit better? Also the gasket is hollow rubber and not foam rubber. Could this be giving it added lift/wedge it does not need?
Second question. How common are headlight washers on a 1971?
