I started the process yesterday; had decent sucess. Twisted off six of the bolts that hold the front bracket to the frame. Question on that issue later.
I have all of the bolts removed and the springs appear to still be loaded, but I have a floor jack under the differential. The springs are pushing down hard on the emergency brake cable and the front of the springs are wedged into the frame where the plate was bolted. How do I fully unload the spring?
With the back shackle nuts removed, is it time to take a sledge hammer and tap the springs toward centerline of the car to remove them from the rear shackle?
sheared off bolts - drill out and re-thread? Or can I drill out enough of the bolt stub that I can pick out the remaining pieces in the threads?
