What does it actually do or prevent? I read different definitions but would like to know in laymans terms. What would happen without it being installed?
Flame Arrestor Function
Re: Flame Arrestor Function
I think that it stops a flame (from backfire etc..) from being sucked into the breather tube -
not 100% sure though.
The PCV system creates suction in the engine and air is pulled through the breather tube.
Just my best guess.......- Top
It prevents a carburetor backfire from propagating into the crankcase, where an explosion could occur because most blowby is combustible unburned fuel-air mixture.
Some years ago I posted a more detailed explanation (see archives), and it was also published in The Corvette Restorer.
Duke- Top
A flame arrester reduces the temperature of the flame going thru it, so that there will not be enough temperature to support combustion on the outside of the flame arrester.- Top
Does anyone know of if a reproduction of this unit is available for a 71 base engine? Mike- Top
Corvette America lists a flame arrestor for a 68 to 72 Corvette air cleaner.
PN 22389 at $8.99 each.
www.corvetteamerica.com- Top
