I have 3 68 conv's and all have the snap in fuzzy for the outer door window seal. Two do not look like they have ever been apart. I am restoring the first for NCRS flight judging. When you buy new seals you get rubber one's from parts suppliers, but their is no way to attach them. What is correct ? Help, neet to make NCRS regional in May.
Early 68 conv outer door window seal
Re: Early 68 conv outer door window seal
Alan,
I looked in the '68/'69 JM and found nothing. In looking at the AIM, it appears that the rubber side bolts next to interior of the door, then the fuzzies sandwich in on both sides of the glass. In my AIM they are all attached by screws that hold them together on both sides. I looked at mine '68 but could not tell how they were attached.Terry Buchanan
Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
Corvettes Owned:
1977 Coupe
1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
2003 Electron Blue Coupe
2019 Torch Red Grand Sport Coupe- Top
Alan, I have a friend that just went through the same thing you are going through, I believe that 68 is different than 69-73 , I will see if I can get you some info on those sealing strips.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Alan I replaced the fuzzy outer window seal on my original owner 68 many years ago, about 1984. There are only two screws to retain the seals to the door. One screw is about 5 1/2 inches from the front of the window seal strip and the other screw is about 1 inch from the rear of the seal strip. The strip is also retained by push in nubs attached to the fuzzy seal strip. My replacements came from GM.- Top
Tim, Jerry, I recall this happening to my friends 68 conv. is there a production change that either of you may recall on that sealing strip?I believe there may have been an early and late design change.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
I think that Corvette Central sells the "fuzzy" ones. They developed them about 10 years ago, and they are far better than the rubber ones - which, you've noted, are not correct.I have 3 68 conv's and all have the snap in fuzzy for the outer door window seal. Two do not look like they have ever been apart. I am restoring the first for NCRS flight judging. When you buy new seals you get rubber one's from parts suppliers, but their is no way to attach them. What is correct ? Help, neet to make NCRS regional in May.
See if the ones they have are what you're after.
PatrickVice-Chairman (West), Michigan Chapter NCRS
