can someone give me an opinion of this cap, it appears old but i am concerned with the spring rivet.
57 breather cap
Re: 57 breather cap
here is a pic of a 57 cap i've had for decades, i think this is the rivet mike speaks ofAttached Files- Top
Re: 57 breather cap
not that i'm aware of. recently got one from CC and its like the one you pictured.i suppose a fella could get creative with a drill motor and couple different sized drill bits and make the repo look like the real mccoy. mike- Top
Re: 57 breather cap
Tom, YES.
None of the repros are correct although some are configured better than others. By that I mean the oil oil area is much better on some than others.
No I don't have any original oil caps. Half of NCRS has called me for them.
Now I don't have the latest 56-57 manual but the older JM shows nice pic or sketch of original oil caps.- Top
Re: 57 breather cap
Well with that in mind, can you tell me when/which caps had OIL-OIL and which caps had OIL-AC?
This is covered in the various Judging Guide books. Actually there are three versions of oil cap emboss to understand:
(1) 56-59E, Oil-Oil with 'slit' shaped reinforcements
(2) 59L-61E, Oil-Oil with 'D' shaped reinforcements
(3) 61L-62, Oil-AC with 'D' shaped reinforcements- Top
Re: 57 breather cap
Aren't there two types of 1957 oil caps..open and closed.Well with that in mind, can you tell me when/which caps had OIL-OIL and which caps had OIL-AC?
Joe- Top
