Sandblasting Body? - NCRS Discussion Boards
Sandblasting Body?
  • Mark A.
    • February 1, 1996
    • 299
    Sandblasting Body?
    Has anyone ever tried to sandblast a body on low pressure? I was wondering if this would be an alternative to soda blasting or sanding. I will be gelcoating the entire body. Would like to hear some opinions on this idea. Thanks, Mark
  • Brandon T.
    • October 23, 2008
    • 872
    Re: Sandblasting Body?
    I wouldn't dare try that..
    • Wayne W.
      • April 30, 1982
      • 3605
      I do it often. Now there is another opinion. Which do you take?
      • Tracy C.
        • July 31, 2003
        • 2739
        Wayne, you probably have this down to a very fine science, but I'm in Brandon's court on this one. I wouldn't try this without several hours of practice on junk body panels first.
        tc
        • Brandon T.
          • October 23, 2008
          • 872
          I'm familiar and good about being easy on certain parts with low pressure and the right media but I don't think this is a good idea. Looks like it would be easy to dip the fiberglass body.
          I have a "little blaster" cabinet and a 10 gal. wheel around and have blasted so many things so from my experience I wouldn't recommend it.
          why do it anyway? buy some soda and a good trap and soda blast it yourself if you're doing this to save $$$$
          • Mark A.
            • February 1, 1996
            • 299
            I was wondering if you were to go at an extreme angle to the panel, almost like peeling it off , versus a straight on approach that would cup the panels. The soda is pretty expensive, and is not reusable, from what I have read? Mark
            • Wayne W.
              • April 30, 1982
              • 3605
              tc
              Yes, you need to know what you are doing, but that also applies to most other methods.
              • Stuart F.
                • August 31, 1996
                • 4676
                My 63 was done this way in 1976 and it is holding up (looks equal to or better than) original, i.e. it's not a new idea or method by any means.
                Stu Fox
                • Doug F.
                  • November 1, 1983
                  • 322
                  i have all my bodys sand blasted, they actually use a mine byproduct called slag, all the pieces inside and out all the nooks and crannys, had one done last month $600, you are paying by the hour so tell the guy to put his best man on it , turn the pressure down a little and take his time, i would not do one a different way.
