I have a 65, 327 in which I removed the oil assembly. I was doing an oil change and just wanted to clean it up. I did not take notice on which side the small incased spring in the assembly unit should be positioned. Should it go towards the engine or the fender? I looked in the AIM sheets but did not see any detail showing this. I did not want to guess and have an oil problem. ( I know Murphy is in the garage with me and if I guess he will make me pay). Thank you for your help all info is greatly accepted. Joe
