65 FI 380 throttle stud and swivel - NCRS Discussion Boards
  • Tom P.
    • April 1, 1980
    • 1814
    Re: 65 FI 380 throttle stud and swivel
    Tom,
    Nice fix on the bellcrank.
    Is that a 62 air meter on you early finned plenum FI unit?
    Bruce B
    Yes it is.
    The entire FI unit is a hybrid of various components and modifications. The most significant mod is the plenum. It was cut in half (down through the center fins) by Bill Thomas about 1961, HEAVILY hogged out, then welded back together. The purpose was to increase flow through the runners and improve upper rpm performance. Seems to work.
    • Richard G.
      • July 31, 1984
      • 1715
      Another idea would be to bore the linkage for a bushing but not all the way through. Leave 1/2 inch at the end farthest from the stud mounting side. Drill and ream to size and add bushing to flush with the end. Bell crank would have to be disassembled to see the bushing end. I am confident this would work will for the hard core guys.
      Best of luck however this issue is tackled.
      Rick
