1963-1994 Unique-To-Corvette Part - NCRS Discussion Boards
    • 43193
    Re: 1963-1994 Unique-To-Corvette Part
    Originally posted by Louis Trohatos (40341)
    Hey Joe,
    Thermostat Gasket?
    Louis
    Louis------
    Actually, the thermostat gasket changed for 1985 and then again for 1987 (to the style with an elastomer bead around the opening to MUCH improve sealing). In any event, these gaskets were by no means a Corvette-unique item. They were used for virtually all Chevrolet V-8 applications.
      • 43193
      Joe, this is truly something someone like you would only know,being a parts and numbers guy.
      if I had to say could it be the spare tire tubs? Not sure of the last year they were aval.
      Edward------
      The spare tire tubs and associated hardware were specific to the Corvette generation. C2 tubs and associated hardware were unique to C2. C3 tubs were unique to the C3 years (with some parts changing over the period). C4 tubs and associated hardware were unique to that period (with some parts changing over the period).
        • 43193
        Re: Lower rear shock nut
        Originally posted by Gary Beaupre (28818)
        Joe,
        Just a guess based on one of your recent postings. Lower rear shock nut.
        Gary
        Gary------
        The lower rear shock nut was the same for 63-82. However, it did not carry-over to C4. The C4 chassis (and most of the rest of the car) is metric.
        Also, the C2-C3 lower shock nut is not a unique-to-Corvette item.
        • Michael G.
          • March 2, 2008
          • 485
          OK Joe, Is this an individual part, or a system and is it a manditory item, or an option available to Corvette only?
          • Scott O.
            • December 9, 2009
            • 100
            Seat Adjuster Knob?
              • 43193
              Michael------
              It's an individual part, it's mandatory, and it's not a Corvette-only available option.
                • 43193
                Originally posted by Scott Orehek (51112)
                Seat Adjuster Knob?
                Scott------
                The same seat adjuster knob was used on all C2 and C3 in the 1965-1976 period and it was a Corvette-unique part. However, it was not used after 1976.
                  • 43193
                  All-----
                  This is one of those question where you need to "put two-and-two together". The first part I would expect that everyone who is on this board knows almost without a doubt. The second part is a little trickier, but I provided a clue in a recent post.
                  Also, over the 1963 to 1994 period, a total of just over 1 million Corvettes were manufactured. Of this total about 685,000 Corvettes had the part in question or, about 69% of the total Corvettes produced in those 31 model years. And, as I mentioned, this is a Corvette-only part.
                  • Thomas H.
                    • August 31, 2005
                    • 1053
                    #24
                    Hmmmm,
                    Maybe 69% were manual transmissions?
                    Reverse light switch?
                    2007 Z06, Lemans Blue
                    • Richard M.
                      Super Moderator
                      • August 31, 1988
                      • 11302
                      #25
                      Ok Joe.....We're gonna keep you up all night! Good thing you're on the west coast.
                      Ok I'll take another shot at it. Not sure if the same one was used on pass cars too, but........
                      cigarette lighter housing?
                        • May 31, 1974
                        • 8365
                        #26
                        Michael------
                        backup lite switch not manditory of early c-2's. no clue as to the quiz answer. regards,mike
                        • Rich P.
                          • January 12, 2009
                          • 1361
                          #27
                          Inside rear view mirror pivot screw.
                          • Wayne W.
                            • April 30, 1982
                            • 3605
                            #28
                            I have always said that the one thing common to all cars was the valve stem core. I would say that part is common to 64-94.
                            • Richard M.
                              Super Moderator
                              • August 31, 1988
                              • 11302
                              #29
                              .... was the valve stem core.
                              Joe called that out in his first post.....those don't count.
                              So I think the teach left the classroom. C'mon Joe, we're in suspense now. It's gettin' late here on the east coast.
                              Rich(anxious student)
                              • Wayne W.
                                • April 30, 1982
                                • 3605
                                #30
                                Yep, I didnt catch that. Then I would guess the side yoke bearings common to IRS rears.
