For years I've heard Bill Clupper refer to the "Copper Clad Aluminum" ground cable that started to be used in 1972. I assumed he was correct, but yesterday when working on the orange 72 I found this:
I had removed the cable because the end that attaches to the frame had a "cut" in the casing and was starting to corrode:
For those that recall the Cincinnati Regional in 2005, my yellow 72 had a similar issue in the exact same spot, and it kept my car from starting when I attempted to leave the judging field. I think that the cable hangs down "just" enough to catch the occasional item, scrape the casing and allow corrosion. Just my hypothesis.
Patrick
Patrick
