66-67 427 motor mount shims - NCRS Discussion Boards
  • Charles A.
    • July 31, 1980
    • 180
    Engine mount shims are called for with 66-67 427 with AC. I am told the reason is to keep the carb. floats level. Why just AC cars? Is there any advantage or disadvantage to use them on non-AC big block engines?
  • Charles A.
    • July 31, 1980
    • 180
    Re: 66-67 427 motor mount shims
    Figured it out if you want to use a c-60 or other fan blade application may want to use.
