Re: Big Block Oil Pick-Up and Screen
Clem, Joe L -- I'm getting conflicting info with what Joe has has said about the L88 pumps having that weird full screen pickup. The thumbnail pic is from "how to Hot Rod BB Chev's" printed 5-'71. On the left is the L88 pump (can barely see ballpoint-written # 3964259 on the flat). To me, that looks like the standard BB pickup (maybe the tube geometry changes according to the application). The pump in the middle [ignore the Melling pump on the right] has black marker "826" (ie 3904826) on the upper pump housing and the (shorter) gear end. This is the standard solid lifter (production) pump.
Now to the Chev Parts catalogs.... The 1968 first issue (ie. Oct '67 P&A30) lists 3904826 as also used for '67-68 CORVETTE w/H.D. 427 (ie. the L88). The Oct '66 catalog (ie. first issue '67) shows nothing specific to L88 -- makes sense because the RPO was not released yet). The first time the 3946026 shows up (in the catalogs I have, at least) is a July 1969 revision of the P&A30, and the pump applies to '67-69 L88's but not L71's (or L89 or L72 or L78, understood) Notation says "w/screen".
Too bad nobody has one of these 3964259 pumps "new in the box", circa 1970.
