I need a filter element for my 65. It is a A/C A165C. I cannot find one through A/C , NAPA/WIX, FRAM, PUROLATOR OR Fleetguard. Any idea where I can get a new element, i'm sure I am not the first to run into this. Thanks Tom
Air Filter help !
Re: Air Filter help !
Corvette Central has it for $50, part#152016. Foam element, right?Big Tanks In the High Mountains of New Mexico- Top
According to the replacement guide, the paper element one is AC A212CW, and it was used on the '65 396 and the '66-'70 for all open element air cleaners. The A165C was used on the 327 with the snorkle air cleaner.Big Tanks In the High Mountains of New Mexico- Top
Tom -- this is what you'll need but you'll NEVER find an NOS one now. Got this back in the early '80s; now turned to dust. there's a paper element GM replacement, good for a driver (the AC number escapes me now, but it's something like AC-353) drops right in the air cleaner housing.
- Top
Is this what you need?
https://www.forums.ncrs.org/attachme...16939&uid=7546
Check the archives, as I recall there is a link to who has them.
- Top
Hi Tom,
Assuming your filter is the same size as that in my '65 365 hp (and I'm pretty sure it is), you should be able to use a disposable Wix 42070 (for driving purposes, of course, not judging). See the link below for measurements. NAPA carries an equivalent as well.
Louis
- Top
Hi Tom,
Louis
http://www.wixfilters.com/filterlook...asp?Part=42070Dick Whittington- Top
If you care about your engine, make sure you don't use the reproduction A165C for anything other than judging. The A165C was a miserable excuse for an air cleaner and, fortunately, GM figured this out fairly early-on (but not as early as they should have). The GM #6419399, aka A165C, was discontinued from SERVICE in November, 1968 and replaced by the GM #6484399, aka, A353C. The latter is a cellulose fiber (paper) filter and it will filter air WAY BETTER than the A165C.
The GM #6484399 has been discontinued now. However, you should be able to get an equivalent replacement from other manufacturers. However, you'll need to cross reference from the 6484399 or A353C part numbers. The A165C is such an "ancient" part number that I doubt that any cross reference guides will recognize it.In Appreciation of John Hinckley- Top
Michael------
The GM #6484399 has been discontinued now. However, you should be able to get an equivalent replacement from other manufacturers. However, you'll need to cross reference from the 6484399 or A353C part numbers. The A165C is such an "ancient" part number that I doubt that any cross reference guides will recognize it.Big Tanks In the High Mountains of New Mexico- Top
Long Island reproduces the A165C now, and the support screen.- Top
