Engines have an L before them. Why? What does the L stand for? Thanks, Bill.
Why were engines called this?
Re: Why were engines called this?
Bill-----
If you mean the "L" prefix for the RPO (e.g. L-36, L-48, etc.) it does not really have any, particular, meaning. It's just that when someone at GM set up the RPO coding system first used for the 1963 model year, they decided that "L" would be the alpha character prefix for engine options. All engine options since then right up to the present day have used the "L" prefix.
By the way, the codes are specific to model years and are often "re-used". For example, the L-68 was first used for the high performance, hydraulic lifter 427 with 3X2 for model years 1967 through 1969. However, for model years 1985-91 it denoted an "Iron Duke" 2.5L I-4 engine.
Also, some might question that the "L" prefix was always used for engine options. If so, what about things like ZL-1 and Z-28? Well, in the GM RPO nomencalture system, RPO's with a "Z" prefix denote an option PACKAGE. Often, it's just a trim package. However, ZL-1 and Z-28 were examples of performance packages which included an engine unique to the package as well as other performance pieces, mostly suspension and brakes in the case of these two.In Appreciation of John Hinckley- Top
1956 Chevy Sedan. 350/4 Speed Hot Rod- Top
Duke------
"Z" prefixed RPO's are not necessarily performance-related. In fact, more often than not they are simply a package of trim pieces. For example, for 1988 "Z06" denoted an interior luxury package for GM "G" body cars.In Appreciation of John Hinckley- Top
yep it depends on the year it was issued. the Z-28 camaro may have been the only "Z" package that showed up as a badge on the car- Top
- Top
I believe they also badged a pick-up truck with a Z-?? package.- Top
- Top
As a semi-interesting aside, persons wanting to buy the initial Z11 offering had to process their orders through Joe Pike for approval; not sure what kind of semi-official Review Board JP sent the applications through, but if you wanted one......- Top
