L78 Carby fuel line and bowls advice - NCRS Discussion Boards
  • Gary C.
    • April 1, 1998
    • 375
  • Dick W.
    • 10483
    Re: L78 Carby fuel line and bowls advice
    Gary, you should be able to have those threads repaired by a competent machinist. They can install a heli-coil and you can reuse your bowl.
    Dick Whittington
    • Rich P.
      • January 12, 2009
      • 1361
      Gary,
      contact e-bay seller flying65 (Barry Blocher) he makes special extended acorn nuts for 65's.
      Rich.
      • Rich P.
        • January 12, 2009
        • 1361
        Gary,
        his e-bay name is flying65vette. Sorry for the confusion.
        Rich
        here's a link.
        • Wayne M.
          • March 1, 1980
          • 6414
          Originally posted by Rich Pasqualone (49858)
          Gary,contact e-bay seller flying65 (Barry Blocher) he makes special extended acorn nuts for 65's.
          Rich --- Gary is having problems with his float valve / seat, not the acorn nut.
          However, I see BB is making extended thread brass bowl inlet nuts for damaged threads, as well as having the regular brass nuts.
          Per '65 TIM&JG, brass inlet nuts were replaced by steel on May 17th, 1965.
          • Rich P.
            • January 12, 2009
            • 1361
            Wayne,
            thanks for setting me straight .
            Gary, as Dick said they can be repaired. I have had many float threads repaired by carb rebuilers.
            Rich
            • Dick W.
              • 10483
              It is not hard if you have the tools. We repaired quite a few when we had the shop open.
              Dick Whittington
              • Gary C.
                • April 1, 1998
                • 375
                Thanks Guys, I'll try the helicoil before I try to find a new bowl.
                Thats interesting about the longer brass nuts being available and will keep it in mind in case I need some in the future. The build date on my engine is 10 May so the brass nuts are correct.
                Thanks again for your help,
                Gary
                Perth Australia
                • Gary C.
                  • April 1, 1998
                  • 375
                  I have repaired it using a heli-coil, hows it look?
