Good evening all. Before installing my new GM Restoration Delco 210 coil wanted to check it for function. Grabbed my Motors manual showing two different checks. With an ohm meter across the primary terminals reads 0 or closed. Secondary check from center tower grounded to case shows infinate or open. Unsure what this means as the manual failed to offer what this reading means
Need some help from the posse. Thanks.
.Need some help from the posse. Thanks.
