327 pad marking - NCRS Discussion Boards
327 pad marking
  • Michael G.
    • November 12, 2008
    • 2155
    327 pad marking
    I have an extra engine with an 870 block cast in Jan, 63. The pad is shown on the attached pic. Can someone tell me what model this came in and what HP it originally had?
  • Bruce B.
    • May 31, 1996
    • 2930
    Re: 327 pad marking
    Mike,
    Post the markings on the pad, the picture is not too clear.
    If the stamping ends in a single "S" it is a 62-64 250 HP passenger car Powerglide engine.passenger car
    • Michael G.
      • November 12, 2008
      • 2155
      Re: 327 pad marking
      Bruce,
      As near as I can tell it reads "FO205S". It has low-horse heads, so you are probably right.
      • Timothy B.
        • April 30, 1983
        • 5177
        Re: 327 pad marking
        Michael,
        That's a Flint block so it would work except for the stampings on a 63 car..
        • Tom H.
          • December 1, 1993
          • 3440
          Re: 327 pad marking
          Interesting to note the two different 0's in the date stamp.
          Tom Hendricks
          Proud Member NCRS #23758
          NCM Founding Member # 1143
          • Michael G.
            • November 12, 2008
            • 2155
            Re: 327 pad marking
            I find it interesting that the broach marks seem to vary in depth across the face of the pad. The "FO2" part of the pad has very pronounced grooves.
            • Tom S.
              • March 1, 2004
              • 1087
              Re: 327 pad marking
              What is the scoop with the serial # stamping? Just courious, did someone remove part of it for some reason? Tom
              • Michael G.
                • November 12, 2008
                • 2155
                Re: 327 pad marking
                Sorry Tom, I don't have any history on this block at all. The pad looks untouched, though. Maybe someone can tell us if some full size Chevys had numbers like these.
                • Bruce B.
                  • May 31, 1996
                  • 2930
                  Re: 327 pad marking
                  FO205S is the marking used on Chevy passenger cars in 1962, 1963 and 1964. It defines the engine as a 327 CI, 250 HP, Powerglide trans used in full size passenger cars.
                  Information is listed in The Lime Book.
                  • Cecil L.
                    • May 31, 1980
                    • 449
                    Re: 327 pad marking
                    Base engines on pass cars didn't get the VIN derivative stamp.
                    • Michael G.
                      • November 12, 2008
                      • 2155
                      Re: 327 pad marking
                      Are those numbers before FO205S some kind of other code, or maybe a re-build date?
                      • Jean C.
                        • June 30, 2003
                        • 688
                        Re: 327 pad marking
                        Is this additional stamping indicative of what would be used by engine remanufacturers? If I recall correctly, some remanufacturers use an alpha code that identifies their company. This one could be a date of remanufacture.
                        Best regards,
