I need to dosome work on the underside of my 59. I would really like to brace the body at the door openings along with cross bracing and mount the body on a rotisserie. Is this something that can be done without adverse effect? Is there anyone out there that would advise against this approach? Thanks David Bodily
Rotisserie
Re: Rotisserie
c-1 and c-2's have been rotated for years . you're on the right track in adding bracing to the door jambs if its a convert. the c-2 coupes don't need the bracing. mikeI need to dosome work on the underside of my 59. I would really like to brace the body at the door openings along with cross bracing and mount the body on a rotisserie. Is this something that can be done without adverse effect? Is there anyone out there that would advise against this approach? Thanks David Bodily- Top
