Need help on wiring harness routing for '65 - NCRS Discussion Boards
  • Jonathan S.
    • February 20, 2009
    • 65
    I am in the process of installing a new wiring harness on my 1965 396/425
    I'm looking at the AIM and the wiring diagram, but I need some help. I have a question on the routing and/or location on where the wiring harness should go under the dash and to the cluster components. If someone could post some photos of these areas that would really help me.
    Re: Need help on wiring harness routing for '65
    Jonathan -
    Photo below is a '67, but the dash harness routing was the same for all '63-'67's.
    • William C.
      • May 31, 1975
      • 6037
      In the center of the opening for the cluster in John's picture, you will see two small clips attached to the harness, Those clips fit into two holes on the top of the instrument case that faces toward the engine that serves as the locating point for the harness to provide sufficient wire length to connect each of the individual lamp sockets to the proper holes in the cluster.
      Bill Clupper #618
      • Jonathan S.
        • February 20, 2009
        • 65
        Very helpful, thank you. A couple of pictures of the routing from the fuse box would be great as well.
          Jonathan -
          See your Assembly Manual, UPC 12, sheet B3.
