454 Oilpan Installation Tips - NCRS Discussion Boards
  • Robert P.
    • September 30, 2004
    • 4
    My 1967 coupe has a 454 block. I removed the oilpan and am installing it with the standard 4 piece gasket set. Any tips on doing this right is appreciated. Thanks.
    Re: 454 Oilpan Installation Tips
    Robert-----
    First of all, I would recommend a 1 piece gasket rather than the 4 piece, original style.
    It's a pretty straight-forward installation. Make sure you tighten the bolts in THREE passes with the final pass to the prescribed torque values. Use a pattern for each pass in which you tighten the 4 end bolts first, then the 4 next to them, and so-on.
