C1 Dulling Door Jams - NCRS Discussion Boards
  • Steve H.
    • November 1, 1996
    • 118
    Hello to all,
    On a '56 I know the door ends were not buffed and thus have a slightly duller appearence, but were the areas by the door latch on the body and by the seat bottom near the sill plates buffed or they duller like the door ends?
    Steve 28428
  • Garry B.
    • January 1, 1991
    • 660
    Re: C1 Dulling Door Jams
    Steve, the answer is yes. The entire door jamb area (those areas you asked about) should be less glossy than the outer body. Be careful though, I have seen a trend towards making this whole area way too flat which is just as incorrect as too glossy. These areas got paint but no buff-out, so imagine what lacquer would look like prior to buffing. That is what you are working towards.
    Garry 18531
    Garry Barnes #18531
    '67 Lynndale Blue Coupe- National TF, BG
    ​'67 Sunfire Yellow Coupe- 4 Star Bowtie,
    • Steve H.
      • November 1, 1996
      • 118
      Garry,
      So I suppose the body lips or gutters under the hood and trunk lid were also duller?
      Steve
      • Garry B.
        • January 1, 1991
        • 660
        Exactly. Good luck.
        Garry
        Garry Barnes #18531
        • John T.
          NCRS Financial Officer
          • January 1, 1983
          • 290
          The buffer pad was approximately 14". If you keep that in mind you will have a good idea of what was buffed.
          Good luck
          John
